jfkmk wrote:
popeyemth wrote:
temperature variations will not build pressure in water lines,period.
there is another issue here. Are you connected to city water without a pressure regulator?
perhaps you had a line freeze and burst or just fail and the water in the lines leaked out.
Hot temperatures will most certainly cause a pressure buildup, hence the existence of thermal relief valves. The buildup is probably not enough to cause damage to the lines. If you're concerned, just leave a hot and a cold faucet cracked open.
The PRV on water heaters are set to open at 150 psi (210*F)
Hot summer temps in excess of 110*F would NOT create an increase in the plumbing system inside an unused RV. There just isn't enough thermo transfer from outside air temps.
OP didn't relieve system pressure after disconnecting water hose.
When he opened the bathroom faucet it spurted.
Doubt it caused any leak(s) otherwise the system wouldn't have had any pressure.
