- tatestExplorer IIPlug goes back in, immediately. Otherwise a tank full of spider webs and/or wasps nests.
- korbeExplorerWe'll the reason I put my plug back in, but not tight, is because I do another flush of the system in the spring, and that includes a bit of water coming out the tank.
- bguyExplorerAnd just what is to be achieved by leaving the plug out?
- Boon_DockerExplorer IIIAnd the beat goes on, and on and on and on ...........
- mike-sExplorer II
enblethen wrote:
What's your citation? To make it easy for others, the first Google hit for "brass bronze galvanic corrosion" says:
Bronze is more compatible with galvanized steel and aluminum.Brasses and Bronzes -0.40
...aluminum is -0.75 or higher. "It will always be the metal with the most negative anodic index which will ultimately suffer from corrosion when galvanic incompatibility is in play..."
High Brasses and Bronzes -0.45
What's zinc coated steel got to do with it? And what support do you have for your claim that bronze is any better than brass? Show your math. - Bronze is more compatible with galvanized steel and aluminum. You need to isolate pure bass.
Seems like we go through the same issues every fall! - mike-sExplorer II
enblethen wrote:
Brass and bronze, being yellow metals, both have similar galvanic voltages.
Most T&Ps are bronze and not brass!
What's your point? - Most T&Ps are bronze and not brass!
- mike-sExplorer II
tn terry t wrote:
I think he was referring more to the water tank.
same reason the BRASS t and p valve doesn't rust also the ball in the valve is stainless
Suburban heaters have glass lined steel tanks, and there is an anode rod to protect the tank from galvanic corrosion (should any cracks develop in the glass lining). Attwood uses aluminum surfaced tanks, which don't require an anode rod, normally.
If you have a Suburban heater, removing the anode rod can result in premature failure of the tank. If you have an Attwood heater with a brass valve, then there's also an issue - putting in a brass valve will create galvanic corrosion with the aluminum tank, unless the connection between the two is insulated (e.g. with a plastic nipple). - tn_terry_tExplorer
GordonThree wrote:
same reason the BRASS t and p valve doesn't rust also the ball in the valve is stainlesstn terry t wrote:
I put in a stubby 1/4 turn brass ball valve in the drain of three different rigs, works real slick
How do you keep the rigs from rusting without the anode?
