RoyB
Oct 28, 2015Explorer III
Its no big deal for me.... I am living with the problem just fine here... I will have to dig back several years where I and a few others were originally having these problems and were actually in discussion with the owners about it.. RV NET CAMPERPAUL K9ERG was one...
Paul actually was somewhat successful soldering on miniature 1/8-inch chip capacitors on the lamp connectors center pin and case ground.
I have photo where Camperpaul solder one on the base of a light...
LEDTRAILERLIGHTS was one brand I had but I will have to look back in my email files to get which company and very nice rep Paul and I were communicating with. They was going to do an different type of regulator circuit other then BUCK BOOST that didn't radiate as much. I never really heard much from them since after I got the cheap 4.99 boards from ebay china. Thats what I have mounted now in my RV ceiling lamps.
I'll get back in a few
Here is one post I made on here in 2010
"I recently installed replacement LEDs in my POPUP and got to field test everything this past weekend.
While trying out my new BATWING antenna I could not pick up any HDTV signals. I went back to my original TV antenna that has worked in the past and it would not work either.
It turns out that when I have my recently installed LED lights turned on, my HDTV signal would be blanked. The TV would go into NO SIGNAL mode. Turn off the LED lights and the TV signal would come back on.
I replaced one of the LED lights with my 921 light bulb and this did not do anything to my TV signal... My celing lights are made by COMMAND ELECTRONICS and are the 30 LED circuit board 510 lumens units. I replaced the CE LED with a LEDTRAILER round LED 380 lumens unit and it also blanked my TV signal when turned on.
I changed out the BATWING antenna with another antenna I have used before in this location and it also would not pick up any TV signals when the LEDs were turned on.
The TV antenna RG6 cable runs along side of the LED 12VDC cable so it must be picking up some sort of radio Frequency Interference coming from the LED boards...
All works fine TV wise as long as I keep the LEDs turned off. (Any one of the three LED lights turned on did the same interference to the TV signal...
Has anyone else experienced this..."
SCVJEFF was another RV NET guyt involved in this...
Looks like all of my comments to the manufacturer is on my other older computer since WIN 10 changeover has come out. Will have to fire that up to get the emails I guess...
Still looking...
* This post was edited 10/04/10 07:50am by RoyB *
Roy Ken
Still looking...
Roy Ken
