Ol__Gold
Jan 17, 2014Explorer
If you apply pressure to one side of that grommet mounted light it will push in. Then you can give it a twist and pull it out. If the grommet has turned hard it may be best to replace them. The lights and grommets should not be expensive. They are commonly found in the trucking industry everywhere. The key is to look at how the wires plug into the back. Get the same type of termination and you will be ok. You won't break the light as they are built very tough. If needed you can push the grommet in along with the light and separate them once they are apart from the vehicle. Hope this helps.
Dan
Dan
44,054 PostsLatest Activity: Dec 18, 2025
