svjim wrote:
When you installed the mount, did Adventurer provide any guidance on where the mount should actually be installed? There is a bath on the other side of the wall where the mount would need to be installed.
Thanks Jim
No, I never thought to ask but I should have. I got mostly lucky, There does seem to be some blocking in there. I hit it with the first hole closer to the trailer wall but the hole farther out I didn't so I then had to use the inner and middle holes on the mount. I took a rough measurement and I hit the blocking with the 8" holes and the 10" holes but missed with the 12" hole... all measured from the wall out.
I'm sure glad I returned the 22" tv I planned on installing as the mount would have been quite a bit farther out and probably would have missed the blocking... that would have been a real mess.
Mine was much easier being the 89RB, because I don't have a shower there so I can use bolts right through.
