LarryJM
May 07, 2015Explorer II
D.E.Bishop wrote:
What about a Heli-coil. May not be correct spelling but drill out the hole, tape with right hand tap(provided with the kit)insert threaded coil in correct size and use either a stud or wheel bolt. Helicoil is correct, coils only, part number is HECR1185-8. Try auto parts store, used for stripped stud threads.
The issue is if it's like the Dexstar rims I showed in my previous post the tapered seat on the rim is some screwy size IIRC and the bolt has the tapered seat on the head to match so any nut would have to have the same tapered seat as that on the rim.
Larry
44,071 PostsLatest Activity: Aug 30, 2026
