deltabravo's avatar
Mar 13, 2014
Let's see your old school tow rigs....
Here's my oldest one:
1984 Chevy K20
K20 translates to 3/4 ton 4WD
Manual locking hubs, 14 bolt full floater rear axle with 4.10 gears
TH700R4 transmission mated to a 350ci with Edlebrock carb and intake, headers (one side leaks somewhere)
Yes, I really do tow with this beast. I've taken 4 trips back and forth across Washington State since November. It turned in to my daily driver this past winter. I've racked up nearly 6000 miles on it since last June when I bought it.
It had some gnarly vibrations when I bought it, which turned out to be a combination of bad rear u-joints and a rear driveline that was too short.
The front driveline vibrates with I engage 4WD or run in 2WD with the hubs locked, so I only leave the hubs locked as needed. Now that snow season is over, I should work on getting the front driveline addressed.
THis is what it looked like when I bought it.
I started repainting it rattle can style last fall.
  • When I bought it, the tires were OK for tread, but were 10+ years old and full of dry rot/weather checking on the side walls.
    I did a lot of looking on Craiglist and finally found a set of tires. It took a long time to find some since it's an odd size: LT 235 85R16, also referred to as "pizza cutter" tires wince they are so skinny. What I found was a set of Goodyear Wrangler Duratracs with only about 4000 miles on them. They've really worked out well for snow driving over the passes, while towing!
  • Cool truck! Thanks for sharing it!
    I'm sort of looking for a 70's Ford F250/F350 just to keep around the house. I think the 70's Fords are some of the best looking Ford trucks.
    I like the long bed on your too. Those flames look nice, someone really paid for the paint job on that truck at one point.
    Thanks!
    Jeremiah
