Ed-N-Dani
Sep 19, 2016Explorer
Lettin it out
OK, next set of questions I have pertain to plumbing. I hooked the water up and found two leaks behind the toilet. One in the shut off valve and one in the flush device. I have decided to just replace the toilet since the seat has a minor crack as well. Unfortunately the wood under the toilet is bad as well, I'm thinking the roof vent leaking over the years caused this.
Now the questions I have are about the drains. Please see the attached pictures. There are two push pull gate type valves under the camper. There are also two gray tubes. I believe through some basic process of elimination that the smaller gate valve is for the "gray" water tank and the larger valve is for the waste water. I'm assuming the "stinky slinky" attaches to this drain and you can run it to the drain once parked if available. Now if there isn't one yet they allow the gray water on the ground then you can open that one and keep the poop valve closed. Now, here is where I'm really confused, what are the two gray drain tubes for? Also, do you have a rough idea of how much gray water and how many "poops" the tanks will hold? How long of a stinky slinky would you recommend and what type of support kit?
Last for now is the wood that is bad under the toilet. I'm not going to start replacing that until tomorrow and before I take it up is there anything I should be prepared for or watch out for?
Thanks!
Ed
Thanks!
Ed
