thomasmnile wrote:
Would addition of a biocide to a full tank of fuel and running the truck so treated fuel is in the entire fuel system be of benefit? 7 months of inactivity seems like a long time......
Is there water in your fuel tank?
Algae will only grow at the water/fuel interface. No water, no algae.
IMO, if there IS water in your tank, you should get the tank emptied and cleaned, then run the fuel through a filter/separator to remove any water and/or dirt.
With a clean tank and clean fuel, you should need no additives, especially if you fill the tank with winter blend fuel, and keep it full. An air space in the tank will allow condensation, and you don't want more water in there!
