HawkTX wrote:
Sorry about the image sizes....I dragged them into Google Photos and didn't really look at the size.
So here is the LONG and SHORT of it.
I flipped the shank because when I put it at the top setting (before I flipped it) it was almost 2 to 3 inches in difference when I measured the front and back. After I flipped the shank and went up one notch that is what I got in the picture above and while it looks high on the hitch it actually measures even for the most part in the front and the back.
The reason I was thinking about taking it back to the dealer, which is an hour away) is they got it so straight when I bought it (with my TV being a GMC Yukon Denali). The guy that hooked it up really knew his stuff and I was hoping to get him, but that might be a roll of the dice because the dealership is a big one.
No big problem about image sizes, just alerting you that the forum software doesn't work well with pictures larger than 600 pixels wide and does not automatically resize them to fit properly. Hence the entire page of posts grows in width which then forces everyone to have to scroll side to side to read the entire text or view the pix.
So, if I am reading this correctly, you started with the hitch 2 or 3 inches too high and flipping the shank reduced that to near level or slightly high, am I correct?
If I am correct, the real fix IS a new shank which has more drop than the one you have. You need one bolt hole longer shank in the drop mode which would drop your tongue approx 1". This will put your setup in the ideal range of tongue slightly down.
These shanks can be used to raise, lower or stay the same in height, yours appears to be very short with not many bolt holes to choose from. You need one that is a bit longer and will have more bolt holes..
IF I am not correct in my assumption and you were 2 or 3 inches too low before flipping the shank, you may need a different shank anyways which would give you the correct holes to get you slightly nose down.
In some respects, if you were 2 or 3 inches nose down I would suggest running it there as long as you are not dragging the tongue. Will not hurt anything as long as the tongue jack is not dragging under normal driving.
I would rather error on tongue low than tongue high, it is a safer place to be. I have always run tongue low on my trucks and trailers and the combination for me always is a stable tow.. I have even had to make emergency maneuvers several times at highway speeds to miss deer running in front of me..
Stomping on the brakes hard results in your tow vehicle front diving and your level or slightly above level tongue will now go well above level which now destabilizes your trailer..
