cccougar's avatar
cccougar
Leveling- Slide In or Out?
Hi Everyone,
I've seen some videos on YouTube where some people level their trailer with the slide out while others say "no" do it with the slide in. I would think with the slide out you would have more leaning to that side so therefore you should have it out. Am I wrong? Thanks.
  • I always level the trailer with slides in, then jacks down, then slides open in this order:
    We open slides in order by size. We have 3 slides. Bedroom closet slide is first (it's the smallest). Living room door side is second. It's the next size up. Back side living room third. It's the largest.
    My dealer "recommended" we level first and put the jacks down second, before opening the slides. This reduces stress on the slide mechanisms. I've done it this way, and never deviated. When pulling the slides out while hitch up, I still lower the jacks on the end of the camper, and often will lower the front jacks to, (still hitched), so the trailer is stable before extending the slides. It's just become our way of life.
    About trailer lean?
    If you park your camper on a level surface , (trailer or motor home, this works for both), extend all the slides and then do a few measurements and determine how much lean the camper has.
    Now, pull the slides in so you can move the camper, and this time but boards under the tires to make up the difference in the lean. When you extend the slides, the trailer will be level.
    Now, if you want to install a bubble level attached to your camper. Install the bubble level with the tires on the boards, but slides in. This is your camper's level spot and when slides are extracted, the weight of the slides will cause the camper to be physically level, the bubble will be off, but the camper will be level.
    (Front to back leveling makes no difference, slides in or out.)
  • Check with the manufacturer of YOUR unit. Mine says do not open the slides if the trailer is not level and the rear stabilizers are not down. You risk twisting your frame if you do not do what you manufacturer directs.
  • Anonymous's avatar
    Anonymous
    Leveling first lessens the chance of slides/mechanisms going out of square and binding and leaving you with a host of issues.
    Being simply unlevel from side to side does not present as many potential problems as both front to back and side to side for slides.
  • When we get to where we are going we always start with leveling it with the slide in and getting close as we can to level. Once at that point we put out our main slide, which is the length of our living space/kitchen.
    We have noticed it does make it lean just a bit. So we level it again. Once locked into place we unhook and level front to back.
    Then slide out the other three slides and we are good to go usually.
