Hi just read where it is advised to put levelling blocks under both wheels. when levelling a dually. Does everyone use this practice ,if so what type of blocks do you use Thanks
After struggling with stacking plastic blocks for years, I switched to these. They work great and you get it right the first time, no more trial and error for the correct height. Andersen sells a camper leveler, but they provide less height than the Rapid Jack. I normally drive up on these vs backing, which can get you fouled up with OEM mud flaps. And yes, I block under both rear wheels.
