Hi just read where it is advised to put levelling blocks under both wheels. when levelling a dually. Does everyone use this practice ,if so what type of blocks do you use Thanks
I don't want all the weight on only two tires, so I put blocks under all 4 rear tires and I need to level the truck from the back. Generally all I need blocks for is the front since my truck rides tail high.
