I'm just about ready to pull the trigger on buying our next TT. Many that we've looked at had electric jacks to level the trailer however the one we have decided on does not. That is a feature that I ...
If I were using a drill to put them down, first time around I'd set the tension by hand. Then, adjust the clutch on the drill so it wouldn't turn them any more. Then, you should have pretty close to the right tension when you put them down with the drill.
