Kayteg1 wrote:
996Pilot wrote:
I've found a spot on my center console that reads level when I'm on level ground (truck camper level). I use my iPhone app with a 360 degree bubble and when I'm parking I get as level as possible for the spot I'm in. .
Are you talking about truck off-road panel showing the level?
I found that and phone leveler kind of low accuracy, not to mention that truck sensor read the frame level.
Even with my camper putting 6500lb on rear axle, my camper still tilts forward comparing to truck frame, meaning even on perfectly flat pad, I have to block front wheels about 3".
That 2017 F350 dually with factory set.
Then glue the level gauge on the door with the camper loaded and a level inside camper on the floor, might work!
