pasusan wrote:
Nvr2loud wrote:
{snip}As I have already stated several times, I don't lift with the jacks, just a 'fine' level after getting the trailer close with my boards.{snip}
Actually this is what you stated initially: On one site I needed to life about 3 inches to level, and the weight was nearly off the wheels, so I jacked slightly higher and put a 1x6 board under the wheels and lowered back down. I am confident that with care, and proper placement, the scissor jacks can be used for lifting.
Yeah, what's the point? He's added jacks JUST LIKE if a person were to change a tire and jack it up but his are mounted. What is the problem with some of you guys? He's not suggested that he's suspending his RV with no tires off the ground but honestly, who cares if he is? I've done exactly what the OP is suggesting he's done in diff ways. Sometimes I am FORCED to load the front trailer weight on the front jacks so I can REMOVE blocks from under my front jack so I can get it low enough to be level. Is this much diff? It sounds to me like some people live in glass RV's ;) You know what they say about people who live n glass rv's!
