popcan
Jul 27, 2015Explorer
justafordguy wrote:popcan wrote:
So, does a good Weight Distribution hitch make THAT much difference?
If it means I can safely pull one of the TT mentioned in my OP, then surely I will have one!
Yes a GOOD WDH does make that much of a difference and a VERY GOOD WDH makes even more of a difference. Get as good of a hitch as you can afford.;)
OK, did a little research, and I'm looking at this unit for a WDH. They tell me it will help control sway and also level the trailer a bit. It is capable of 1000lbs Tongue Weight. Any advantage to going to a 1200lb version? It's not a lot more $.
https://www.hitchweb.com/product/88/92-00-1000/Weight-Distribution-Sys.-integrated-SwayBETTER-than-Chains-CAP-1000-lbs.-TW
