3 tons wrote:
snip.... the charger reverts back to and holds at 13.6v…Charger stays at 13.6v to again repeat the 14.6v charging cycle in 8 days, or presumably triggered upon reaching a voltage somewhat lower than 13.6v…
I would not want to float an LFP above 13.4 volts. 13.2 - 13.3 is better. I don't know anyone that recommends holding LFP long term at 100% charged.
14.6 is also higher than necessary and is more likely to cause a fault in some lower cost brands from CN that many look at.
This generally gives the standard PD or the PowerMax with adjustable voltage an advantage. Both drop to 13.2 volts for long term.
That is my opinion. Good luck to the OP.
