I'm not sure if it's the same warranty, but there was a lifetime warranty provided on the 06, 07, and 08 gasoline powered trucks. It's a pretty good warranty. According to Dodge, the only requirements are to follow the maintenance schedule and come in for a free inspection every 5 years. Doesn't have to be dealer performed maintenance. I took mine in last year for the inspection and they found a slight leak at water pump. They replaced the whole part free of charge and without any hassle. The dealer even tossed in a new thermostat even though that's not one of the covered parts. I'm not sure what this lifetime warranty covers, but the previous Chrysler lifetime warranty covered this"
"Parts Covered
The Lifetime Powertrain Limited Warranty covers these parts and components of your vehicle’s powertrain supplied by DaimlerChrysler Motors
Company LLC:
Gasoline Engine: cylinder block and all internal parts; cylinder head assemblies; timing case, timing chain, timing belt, gears and sprockets; vibration
damper; oil pump; water pump and housing; intake and exhaust manifolds; flywheel withstarter ring gear; core plugs; valve covers; oil pan; turbocharger
housing and internal parts; turbocharger wastegate actuator; supercharger; serpentine belt tensioner; seals and gaskets for listed components only.
Transmission: transmission case and all internalparts; torque converter; drive/flex plate; transmission rangeswitch; transmission control module; bell
housing; oil pan; seals and gaskets for listed components only. NOTE: MANUAL TRANSMISSION CLUTCH PARTS ARE NOT COVERED AT ANY
TIME.
Front Wheel Drive: transaxle case and all internal parts; axleshaft assemblies; constant velocity joints and boots; differential cover; oil pan; transaxle
speed sensors; transaxle solenoid assembly; PRNDL position switch; transaxle electronic controller; torque converter; seals andgaskets for listed
components only. NOTE: MANUAL TRANSMISSION CLUTCH PARTS ARE NOT COVERED AT ANY TIME.
All Wheel Drive (AWD): power transfer unit and all internal parts;viscous coupler; axle housing and all internal parts; constant velocity joints and boots;
driveshaft and axle shaft assemblies; differential carrier assembly and all internal parts; output ball bearing; output flange;end cover; overrunning clutch;
vacuum motor; torque tube; pinion spacer and shim, seals and gaskets for listed components only.
Rear Wheel Drive: rear axle housing and all internal parts; axle shafts; axle shaft bearings; drive shaft assemblies; drive shaft center bearings; universal
joints and yokes; seals and gaskets for listed components only.
Four-Wheel Drive (4X4): transfer case and all internal parts; transfer case control module and shift mode motor assembly; axle housing and all internal
parts; axle shafts; axle shaft bearings; drive shafts assemblies (front and rear); drive shaft center bearings; universal joints and yokes; disconnect housing
assembly; seals and gaskets for the listed components only."
