So my new tires rub as I knew they would. It is not doing any damage, just rubbing the inner fenders and my flairs a little but it is annoying. So I am stuck lifting the front end. Going to do a si...
Well it seems like you know what you need to do to keep the wide front tires.
I found that with my 2WD Ford, I had to get a certain wheel offset when I replaced the chrome rims with aluminum ones rated at 3,400 pounds, the offset needed to be correct. I am not sure if your tires would help by moving outward or inward, but you might also check that too.
