bleedwater's avatar
bleedwater
Lighten 2009 F250 to increase 5th wheel kingpin margin
My 2009 F250 Lariat Crew Cab 4x4 Deisel Superduty has a GVWR of 10,000 LBS. With 5th wheel hitch, 160 lb driver, full fuel and no other cargo in the truck, the CAT Scale reports steer axel 4920 lb, drive axel 3360 lb, gross weight = 4920 + 3360 = 8280. 10,000 - 8280 leaves 1720 lb for the fifth wheel kingpin. My 5th wheel literature states that my unloaded 5th wheel trailer weighs 9790 lb (dry kingpin of 1615; dry 5th wheel axel of 8175). I will visit the CAT scale soon with the trailer to get exact kingpin weight but the challenge is clearly to create some margin in my truck's 10,000 GVWR with trailer kingpin attached.
This is typical of many 3/4 ton pickups pulling a 5th wheel. I have run all the numbers thru safe towing calculators and I have good margin to spare everywhere except where the kingpin weight is added as truck cargo and I need to stay below 10,000 lbs.
Question for F250 owners :
a) Have you removed rear seats in your truck?
b) Have you removed tailgate? What did you do with the backup then?
c) Have you removed the standard Ford 12,000 towing receptical
d) Spare tire removal seems more drastic than I want to go
I have a set of AirLift 5000 ultimate air bags ordered to help with leveling.
e) For 5th wheel towing do you agree to "T" air feed so both are identical?
f) Within the year I will be due for some new truck tires. Currently I have LT275/65R20E Goodyear Wrangler All Terrain. Any better choices for a person who is running close to their truck weight limits?
