brulaz's avatar
brulaz
Lipper Electric Stabilizing Jacks - Problem
Well the first major problem with the new trailer is the rear Lippert electric stabilizing jack. On our trip to Florida, it went down one night but would not retract the next morning.
Not manually either. The thing was jammed solid. The night was cold (6 below) so perhaps the mechanism was froze up somehow. But then it looked free of ice so figured maybe it was a mechanical jam somewhere.
Anyway, we had to get going, and as the whole thing is only attached with 4 bolts and an electrical cable, I decided to just remove it. But first I wanted to lower the front of the trailer to lift the rear jacks off the ground a bit.
Unfortunately I had left the trailer hitched to the truck that night as it was level with the WDH bars removed (and it was cold and late). So there was no way I could lower the front of the trailer without first raising it to unhitch the truck.
Maybe if I had had my morning coffee I would have realized that this was a stupid thing to do. Raising the front with the rear jacks extended puts more weight on them than they are designed for. They get crimped a bit, as I found out. Anyway, I got the assembly off and got going. I should have just removed the bolts, cut the cable and pulled ahead. Or, even better, ...
I later discovered that it was actually the motor/gearbox assembly that was frozen up. After removing the motor I could easily close up the jacks by hand. And after the motor/gearbox warmed up, it worked fine too. So I could have fixed the problem by just removing the motor/gearbox, hand cranking the jacks up and replacing the motor, (waiting for it to unfreeze), and drive off. Or by heating the motor/gearbox.
Since then I've put the whole thing back in place and it still works, sort of. With the jacks crimped as they are, they can't be as rigid as they originally were and may not last too long, we'll see.
So be careful of putting these things down when it's going to get below freezing, and when you've been driving in the wet all day.
EDIT: I see others have water problems with the Lippert jack motors
Full-of-water
  • Thanks for this great info. It all makes sense and I will be travelling with a set of four manual jacks that I'll keep in the trunk when doing late season travelling in colder temps.....modern push button conveniences come with their unexpected limitations..... I can't wait till one of my tiny schwintek slide out motors quits while travelling....I am considering buying a spare (worth a few bucks $$$.) Has anyone else bought one and have you had to replace one yet on your unit??
    Lou
