braindead0
Jul 01, 2016Explorer
Lynnmor wrote:Having a zerk fitting does not mean the grease is entering in front of the seal. I've had boat trailers and one popup that had a zerk in the spindle (NOT in a dust cap like a bearing buddy) and those both had the grease entering between the inner/outer bearings.. and no means to allow grease to exit through the outer bearing (both had a large washer that effectively blocked the exit). Those hubs are not the same as ez-lube/super lube hubs and that was what I was trying to determine by checking with Lippert.
They can name them whatever they want. It either has a grease fitting or not. It is just a hole drilled In the spindle that exits right in front of the seal. Good luck.
Use them as designed or not, don't care. Just trying to help others positively ID.
44,066 PostsLatest Activity: Jul 25, 2018
