wibigfoot's avatar
wibigfoot
Lippert Frame? - Coachmen Apex
Through reading a number of topics here I find more people not a fan of Lippert frames than those that are.
We narrowed down the RV to a Coachmen Apex and the sales rep stated they use a Lippert frame on them.
All that's going through my head is to stay away from them but I have no reason to why other then what people say here.
So run away or don't worry about it?
  • You might want to look for TTs that use the Bal Ultraframe. Not many out there there that I know of. Lance uses them and I think the Jayco Whitehawk has them. You could always call Norco Industries and ask them. Nash and Outdoors RV (owned by Nash) use their own heavy duty in-house built frame. If I were to do it all over again, I'd buy something that has other than a Lippert frame. Yes, Lippert does make a weak frame that is used on some ultra-lites (it's an "ultra-flexible" frame) and prone to cracking and other issues. I have seen this frame on 5 or 6 makes/models.
  • Any of them can have problems depending on what they are subjected to. I think someone said the new frames have the reinforcement plates in the areas that they were cracking.
    cracks
    Repairs
  • The only problem use to be some Lippert frames on 5th wheels around the pin box area...
    Haven't heard much about that for a couple of years now...
    ....and, as stated Lippert supplies many many thousands of frames. Normally folks don't post about how HAPPY they are with their frame.
  • Lippert makes quite a variety of frames from scrap to good. I happen to have a scrap one that cracked in four places in a few thousand miles. I tried to tell a fellow camper with an identical unit, but he refused to even bend over and look.
    Be sure that you never buy a frame that has been constructed with a three piece fabricated "I-beam".
  • Huntindog wrote:
    I really don't know what all the fuss is about.
    Same here. I've got a 2014 Coachmen Freedom Express 192RBS and haven't had any frame issues, at least none that I know of. This particular model has an open underbelly and I've been under there quite a few times for one reason or the other and haven't spotted anything that would concern me at all. This spring I'll no doubt be under there again as I'd like to paint the frame, as I've done with any previous trailer I've owned, but I'm not expecting to see any problems.
  • I'll bet you that most RV owners don't have any ideal what frame is under their unit!! I have owned a 2003 and a 2008 Keystone trailer - the number one selling manufacture in the world - and they use Lippert frames - 10s of thousands of them. What does that tell us!!
    Just Saying....
    It's like tires - some people swear by brand X. On the other hand, some people will curse brand X.
    You deside.
  • Lippert was, not sure if they still are, making two styles of frames.
    One uses I or H beams, the other uses stamped sheet metal.
    There website indicates they only use I beams and tubular steel. I didn't see any stamped steel indications.
    Lippert Frames
  • I really don't know what all the fuss is about.
    I have had 3 TTs. The first one had a very heavy metal. The welds were very bad looking... But it held up well with no problems.. No idea who made it< The axles were Dexter, so that may have been thr frame as well. My second TT was new. A 2001 Fleetwood Wilderness. The welds were better looking on this one, but it did need a couple of repairs over the years. No weld failures, but stress cracks and spring Hangers breaking off. Since I weld, I was able to make it better than new myself.
    My present TT is a 2010 Palomoino Sabre. It has Lippert frame and axles. It is by far the best of the three. The welds look first class, and it has been absolutly trouble free.
    There has been talk that the TT manufacturers spec the frame,,, and some will cut corners in the specs to make it cheaper. Perhaps that is why mine is so flawless..
    Or maybe like anything else, people tend to complain about a problem when it crops up, but not say anything when it doesn't. I doubt that most people that haven't had an issue have any idea who made their frame. And since Lippert is the largest manufacturer by far, it stands to reason that their will be more problems...
    The only thing I can advise is to look at the manufacturers for frame troubles on the units they make, rather than the manufacturer of the frame.. Some brands seem to have more issues than others.. That tends to point to the first scenario I mentioned as having some validity.
    And generally speaking many frame problems are pretty easy to fix if you can weld. If not, then it can be fixed for a price.. There are many other problems that would cause me to lose sleep first.
