leftybj
Apr 29, 2013Explorer
Olde Volks Place wrote:
Where would you find that box? sorry if i missed that part of the info.
also if you have a lippert frame would it be safe to assume that they use a lippert slide mech to, or mix n match components one mfg to another.
I found one under the kitchen sink behind a panel on the floor and I relocated it up on the wall above the panel so I can access it if necessary without taking everything apart. All I have to do is open the door under the sink and there it is. I am looking for the one on the other side and believe it is behind the power converter. I downloaded the manual on the converter tonight and will pull it out in a few days. I will find it and relocate it if I have to build a small enclosure that mounts on the cabinet wall. I will have to stain it to match but I will have access in case of emergency. This is worth the trouble as I had to go into the manual override mode on the unit under the sink this weekend to move the slide in. It was my fault that the slide lost position information as a book was behind one side when we moved it out.
