leftybj
Apr 30, 2013Explorer
leftybj wrote:Olde Volks Place wrote:
I am learning so much info on this RV.NET site, Thank You all.
So my DW and I will be ordering a Jayco 324BHDS in the next several mts, 1st question--Can you order direct from Jayco if so knowing this info is it possible they would locate these controls where you can get to them easily, because I know where I would like them if they would locate them where specified.
2nd question--is there one box per slide with 2 motors, as the 324 has 3 slides 2 rear for the BH and one for sofa/dinette, so I'm looking at 6 motors and 3 control boxes right.
To bad the TT MFG's aren't like Burger King meaning they build it like you would build if you could. I would put override mech's close to where they went,under and behind seems like more work to me I like the K.I.S.S. method of life,seems to have worked this long why mess with it.
opps
There should be one controller for each slide and it controlls two motors. I see no reason why they cant locate these units where you want them as they have plenty of cable that was just taped up in a bundle. Make sure that they are going to install this type of slide system before you require they locate the controls in a particular place
