- Super_DaveExplorer III had a situation where after draining the tank and putting the cap back on immediately, the cap would fill up with residual water from the walls of the pipe. Everytime I took the cap off, water would spill all over me. Now I drive home with the cap off so that the pipe dries out and finishes draining.
- Joe417ExplorerI use the twist on valves because I don't like surprises either but the valves are usually easy to replace, as long as you can get to it. Only 4 screws and nuts and 2013 shouldn't have any rust. Just rinse and drain it good and hold your breath. It only takes a few minutes.
BTW, the last valve I had to replace had a damaged slide where something was in the valve when it was closed. Oil wouldn't have helped. - mooring_productExplorer
Paradox123 wrote:
I used one of those temporarily, and they are OK if you stay in Florida, but in colder climates, whatever leaks past your main valve will freeze and become undumpable.
Never thought about that.
What about antifreeze in the problem tank? I also would think that most of us don't camp when its below freezing..
I have only used my heater twice - billyray50ExplorerI second the Valterra twist on valve cover. Had it two used older campers. No problems in colder weather either. Cheap and easy quick fix.
- Paradox123ExplorerI used one of those temporarily, and they are OK if you stay in Florida, but in colder climates, whatever leaks past your main valve will freeze and become undumpable.
- mooring_productExplorerI have had this issue sense I purchased my Lance 881.
I rinsed and greased everything but couldn't get the grey water to hold.
I finally installed one off these last week. No more surprise splashes when dumping.
twist on valve - FastbritExplorerChalet rv had lots of problems with that mechanism also.The cables are too long.They now have electric valve for black and grey tank in they're campers.
- Paradox123ExplorerI had this problem. The source was a bad mechanical design, not something stuck in the valve. I replaced the valve three years ago with a 12 volt electrically activated valve and have no further problems.
- GeterdoneExplorerThanks I will try these fixes....someone suggested dumping cooking oil in empty tank and flushing it thru to lube valve...? Not sure if that is a valid option.
- miskeetaExplorerLance 981 here the only sure cure is put in a second knife at the very end of the line been there done that
44,066 PostsLatest Activity: May 12, 2026
