toddb
Jan 08, 2021Explorer
I went without vehicle charging for when I switched over, I only used solar. No problems until the fridge upgrade.
I use a small one now on factory wiring and would recommend it if you want vehicle charging. This will keep the voltage stable as you don't want the BMS to disconnect on over or under voltage from the alt.
