- RFVExplorer
VTR wrote:
Almost bought one today, but than I read it might shut off at 7000 thousand feet. Experience with this?
I have one and have used it camping in the AZ White Mountains at 9000 feet. No problems whatsoever. Heat like a champ!
Rudy - manualmanExplorer IIBuddy's are designed with a thermocouple and flame jet apparatus that won't burn hot enough if the O2 starts to be depleted and the thermocouple then turns off the LP supply. It works great at regular altitudes, but at high altitude, the ambient O2 is already so low that the flame jet is reduced and won't satisfy the thermocouple.
Basically high altitude tricks it into "thinking" that it's in a regular altitude room and that the oxygen is being dangerously depleted and that it is saving your life by turning off. - lillyputzExplorer III also installed a Olympian Wave 8. It works great. I would highly recommend the Wave.
- scrubjaysnestExplorerWe've used ours for years with no problem.
- Tom_M1ExplorerMy Buddy heater works at 7500 feet. I removed the built in regulator and plumbed it into the low pressure line that feeds my cook-top.
- Ron_SchulzExplorerIn my last RV I had installed an Olympian heater. Worked great until I moved out here. Than I started to notice a propane odor whenever it was on above 6000'. Wasn't a leak, just smelly. I now have an Big Buddy. No problems at all. We were in the higher elevations most of the fall and worked great...
- VTRExplorerInteresting, thanks for the input folks.
- tplifeExplorerI'm leaning toward an Olympian WAVE heater due to the safety advantages vs. the Buddy series. Flame issues at higher elevations might explain issues with the Buddy brand.
- AJBertExplorerMy dad has one of the newer ones with the 7000 foot limit. It "worked" above 9000 feet most of the time. It would turn off now and then but wouldn't start up right away. It wasn't until we were done hunting that we found out about 7000 foot deal.
My brother has an older one that we've never had a problem with. - beemerphile1ExplorerThe way I understand it is that the safety O2 sensor is actually a flame sensor. If the pilot is too small it won't operate.
44,071 PostsLatest Activity: Aug 16, 2026
