GMandJM
Sep 17, 2013Explorer
DiskDoctr wrote:
Maybe this one instead?
Bissell Professional Spot Remover
Do they all use a spray nozzle for applying the cleaner?
I've not seen that particular machine before. It looks like what would happen if Darth Vader
and R2D2 had a baby. Cute.
I'm fairly certain that in manual mode all use the spray nozzle on the suction handle to dispense the cleaning solution (you mix it with warm water in the "clean" tank).
Using the manual mode, the brush on the bottom does not spin.
In the automatic mode (to use the round brush) on the bottom, the machine will dispense the cleaning solution via the small 'jets' in with the brush.
This reply is probably clear as mud. If so, I apologize.
Anyway, thanks for the photo of that machine. Always nice to have a replacement in
mind for when our current one stops working.
44,071 PostsLatest Activity: Aug 30, 2026
