Hama wrote:
path1 wrote:
If your lucky, on the other side of plastic there might be a part number molded into plastic. Then maybe you can match up, but doubtful. In looking for replacement if you can't match up old screw holes I would put something over the old screw holes to keep moisture out before mounting new light.
yea, i guess ill take it off tomorrow and hope for the best. Thanks for the advice
I see numbers stamped into the base from your picture. What's the difference, though? It's a fairly generic 12V fixture and anything you can get at an auto parts store will work for replacement.
I'd be looking for a marker light with either yellow or clear lense.
