Hama's avatar
Hama
Little help with a light fixture
Hello, New to the forum. Been doing a lot of reading here, seems like a great place with awesome people and advice. I just bought a used 2005 starcraft rancher. First time owning a travel trailer. A lot to learn and hope all goes well. Ive been trying to fix some things up and came across the light fixture under the outside steps. Looks to be pretty shot. Does anyone know what replacement part it is. Ive been searching but cant find anything that looks like it. Might be because most of it is missing. Any info would be great. Thanks in advance.
  • path1 wrote:
    If your lucky, on the other side of plastic there might be a part number molded into plastic. Then maybe you can match up, but doubtful. In looking for replacement if you can't match up old screw holes I would put something over the old screw holes to keep moisture out before mounting new light.
    yea, i guess ill take it off tomorrow and hope for the best. Thanks for the advice
  • If your lucky, on the other side of plastic there might be a part number molded into plastic. Then maybe you can match up, but doubtful. In looking for replacement if you can't match up old screw holes I would put something over the old screw holes to keep moisture out before mounting new light.
  • Highly unlikely you would ever find a replacement part. I would purchase a generic outdoor RV fixture online.
    Something like this.
