billyg wrote:
Hi looks nice. I never did like the table it comes with. It takes up to much floor space. Our little 5.7 was to have a table. No thanks. I can't remember did you get your legs figured out? Bill
Hello Bill,
If you are referring to the jack 'legs', then no, I have not done anything with them yet (ie. removing the attached pads and replacing them with removable versions).
My next modification will be to the bottom of the 'pantry or shelved closet' area. The bottom of that area is one very large 'pit' that can only be accessed by digging into it from the top. Hard to see what is in there and hard to get items on the bottom. I am going to put a cover on that top to make a shelf then cut out the azdel siding and make a door to gain access from the side.
This would be explained better with pictures. Coming soon.
Del
