lee_worsdell's avatar
lee_worsdell
lly duramax boost
what should boost be at when running 70mph on flat ground.Having problems with turbo codes,2563.I have never seen my boost go over 22-24 when I stomp on it. Have no idea were it should be.
  • christopherglenn wrote:
    That is a "Turbocharger Boost Control Position Sensor Performance" code.
    you are over a grand for the part and install at a dealer (part is close to $700 for the lbz).
    I ended up changing my turbo, to many possibility's of the vanes being choked with soot, and having to pay change it 6 months later.
    Stock ~22 psi boost is all they make.
    That is the code mine shows. Pull the Sensor pass side of the Turbo and clean it. All is well, this Sensor changes the fingers on your Turbo. If its not working, your Turbo is working at the default setting only.
    Bolt under the Sensor is an 8MM 12 point socket. Its fun to get this bolt out.
    Pete
  • That is a "Turbocharger Boost Control Position Sensor Performance" code.
  • If you don't get an answer here try the www.dieselplace.com forums.
    The meduim duty forum has some folks who know everything there is to know about the Duramax engines.
