Because the tires are ST are they safe to use with 80psi and an average speed of 60mph? Everybody has opinions but I would like to know if anybody has the same tires with good results?
Let me see if I can stand under what you are asking; The people that designed the tire have it labeled for 80 PSI max pressure, right? And you are asking random folks on the net if the tire will stand 80 PSI? The fact is it will not only stand the 80, but will not stand the maximum load
unless it has 80 in it. You need to weigh your rig to be sure the tires have the weight rating to handle the load.
As for speed, the sidewall will be labeled with
maximum speed. your average speed will be less than that.
