- brulazExplorer
Me Again wrote:
45Ricochet wrote:
Not to mention the short wheel base trucks don't come with 6 wheels :W
???? You sure? Chris
Saw a RegCab 8' bed RAM dually recently.
Looked stock? - HannibalExplorerI've had both. The short bed is a little bit easier to maneuver around parking lots but the long bed is worry free and a standard hitch is much lighter, less costly and less moving parts to wear out. Since our kids are grown and out, our next truck will be an extended cab long bed.
- michigancougarExplorer6.5' bed here with 3/4 ton but added the auto slide hitch this time so it slides back automatically in turns - no need to manually get out and pull the lever so no chance of hitting cab unless you truly jackknife the rig. pullrite auto slide is the best invention I have found!
- Cummins12V98Explorer IIIRAM Dually Aisin 4.10's factory rear air ride, B&W hitch and Highway Products tool box. GOLDEN
- Me_AgainExplorer III
???? You sure? Chris - 45RicochetExplorerFull time = Big box :B
The longer wheel base will ride better, the non slider hitch will have less movement and you'll have more room for stuff. Not to mention the short wheel base trucks don't come with 6 wheels :W
Now if it was a DD or garage issue you'd have to decide, but full time means getting the right tool for living full time. - therinkExplorer2011+ GM HD short beds have 36 gal fuel tanks
- LearjetExplorerThere is a difference between cabs also...Crew Cab and long bed makes for a LONG truck that is hard to park in a regular spot. Like trying to park on a city street between parking meters.
Now a long bed with a super cab is about the same length as a Crew Cab short bed (Ford).
People often leave out the CAB part of the equation. You need to look at overall length and wheel base. Especially if you park on a garage. - Me_AgainExplorer IIIWe had two long bed standard cab trucks. For our 2015 RAM crew cab we went with the short bed and B&W manual slider. Filled the rest of the bed with boxes from old truck. Had to modify the front box.
Happy with setup.
I installed the factory pucks and use the Demco Hijacker 6099 picture frame with RVK3270 hitch.
Chris - HalmfamilyExplorerLove our 8' bed. Have a 100 gallon aux diesel tank and still have room for firewood in front of the hitch. Also put our portable dump tank between the hitch and tailgate.
