billtex
Oct 28, 2013Explorer II
I have seen SB campers used on LB truck w/fuel cell. I have never seen a LB camper on a LB truck and fuel cell. I would be more concerned about COG then I would floor support.
You will need to visit the scales to see what is going on with your axle loading.
You MIGHT be unloading the front axle...
Good luck, B
Edit; Also, plywood would not be the material of choice to add reinforcement...it has no strength in shear.
Steel beams/plates or unidirectional composite maybe...but now you are adding weight and/or $.
Why not get an under bed fuel cell? Then you won't have this problem.
Good luck, B
