Overall length can be an issue if you plan to use the truck to get around while unhitched. I went from a 19' SRW extended cab short bed to a 22' DRW crew cab with 9' deck. The width really has not affected my parking as much as the length because you cannot jut out of spot so much that you obstruct the aisle.
We haul a camper on the truck and have a hitch extension which adds almost 3' to the length. At 25' length, forget about fitting in to one parking stall and you better look for end spots when parallel parking or plan on taking two spots (double meter fees).
If you feel that a 22' length is something that will work for you, I recommend the long bed for fifth wheel towing. You typically can have a larger OEM fuel tank and a stronger yet less expensive fixed hitch. Although I loved the mobility of a short truck, the limitations of its size was the reason I sold it.
