dclaarjr wrote:
I don't want to hijack this thread but it may also help the OP.
My low point drains are at the drivers side rear corner. Would it cause an issue to hook up an outdoor shower set up to that? I figured I could always disconnect them from the outdoor shower to use them for their intended purpose when I winterize.
I don't have an outside shower. My low points are pex tubing and didn't have any fittings on the ends since the shutoff valves are inside. To each one I added a flair-it pex x npt male, then a npt female x 3/4 male garden hose adapter and then a female x quick connect garden hose connector with built in ball valve. I sometimes shut the ball valves and open the low point drain shut offs inside so I can connect garden hoses outside or I can hook up an outside sink. Nice to have hot water outside without cutting a hole in the side of the trailer if you don't need to.
