93STPD wrote:
Any idea where I can find a longer outside shower hose? Or is there a mod to extend it? My outside shower is located on the passenger side of the camper right under the awning. It's kind of in a stupid place. I want to make it long enough to bring to the back of the camper (about 15 feet) The fittings on the faucet are oddball. The only other idea I have is to cut and splice the existing hose.
As stated the hose is the same as used in a house. The connections use npt threaded nuts on the end with a flat rubber washer seal. So adapting to the existing hose with another hose is easy and you can still put the shower wand back on if needed.
