jmtandem
Mar 19, 2016Explorer II
Thanks....I guess the pic posted. None of you see a problem with the spring bars being so low to the ground? I scrape so much with them like that. I lift the truck so high as it is just to get the second link hooked up there is no way I would be able to get any more chain links connected. I am 110 lb female hitching up, and the tension is just too much for me.
If you use your tongue jack to help with the tension on the spring bars, far less effort on your part is needed to get them just right.
44,068 PostsLatest Activity: Jun 21, 2026
