hohenwald48
Mar 21, 2016Explorer
lukenick wrote:Redterpos3 wrote:lukenick wrote:
None of you see a problem with the spring bars being so low to the ground? I scrape so much with them like that.
It looks to me that the drop on the ball coming off your truck is too much. You could raise the ball higher on that hitch (to the top holes), and save 3-5"
They had to add that drop because anything higher and the trailer would not be level due to the underslung coupler. It is an 11" drop and the head is mounted to the very bottom holes.
Yeah, if you raise the ball as suggested by redterpos3 then you'll just have a problem with the back of the trailer dragging. You can tell in the pictures that you have the trailer level with the drop as is.
When is you dealer going to take a look and give something a try?
