SoundGuy
Mar 22, 2016Explorer
lukenick wrote:
Either the coupler needs to be mounted on top or I will need a new hitch system.
There's little sense in modifying the trailer when the simple solution is to switch to a weight distribution system which by it's design offers maximum ground clearance. Here's a pic of an Equal-i-Zer Weight Distribution Hitch mounted on our previous KZ Spree. As you can see there are no chains and the spring bars are straight unlike the "hockey stick" spring bars your current round bar chain WD system uses. There's also no need for a separate friction sway bar as sway control is a function of the design of the Equal-i-zer.
