kennyd63's avatar
kennyd63
Look Here*****
I have a P/T in MI I notice that there is a red and white hose with a screw on cap from the bottom on each hose of the trailer, this is not nowhere the hot water tank. Is this is another way to winterize your T.T.?:h
Thank you in advance!!
  • beemerphile1 wrote:
    Low point drains but I have no idea what "P/T in MI" means.
    I would say you have about the worst thread title I have ever seen on here. Totally nondescript but it did get me to look.
    Park Trailer or D/T destination trailer in Michigan..:W
  • When you open those low point drains, also open the faucet, farthest from the drains, to allow air to get in the lines. You still need to use RV antifreeze to protect drain traps and pump some into the plumbing lines to protect toilet valves and water pump. Don't forget the outside shower !!!
    Draining lines, prior to pumping in antifreeze, prevents that water from diluting the antifreeze.
    I agree - I first thought he was saying he is a Part Timer in Michigan .
  • Low point drains but I have no idea what "P/T in MI" means.
  • powderman426 wrote:
    From your description, I would say low point drains.
    Red is probably hot water line...
