- buck_n_duckExplorer
PawPaw_n_Gram wrote:
We purchased a Forest River Cherokee Grey Wolf 26BH in September 2011.
The first set of tires wore out quickly and badly in 2,000 miles. The PDI told me to run them at 40PSI for a 'softer ride'. They were 50PSI tires. My fault for not knowing TT tires must be run at full inflation.
The 26BH is a nice trailer - no slide. The 28BH has the dinette and couch in a slide.
The good - no real issues with the TT.
The furnace thermostat burned out at 13 months - Suburban paid for the replacement and install.
The faucet started to leak water soon after we got the trailer. I couldn't figure out how to stop it, so went to Home Depot - bought a Moen and put that in. No more leak. Looking at the original later - I realized DW was pulling up as she would turn it and unseated the high output - resulting in an internal leak.
The bad - nothing really. It is a bottom level entry trailer. The tanks are not enclosed or protected. You must winterize and protect it from freezing weather. Our water heater was under the head of the bed - road side. Getting to the bypass valves involved removing most stuff from under the bed and almost having to crawl into that space to reach all three valves.
The dislikes - the no-slide was an issue. We've had five grandchildren and two grandparents in the TT for five nights. It rained two days. We survived and amazingly no one was killed.
The jackknife sofa is uncomfortable for sitting more than a half-hour or so. I put several 1/4 in high x 4 in wide x 4 ft long pieces of sheet aluminum between the springs and fabric under the sofa and made the sofa better.
The air conditioner is not ducted or thermostatically controlled. The controls are on the unit. Yes, the compressor will turn off when it reaches the temp setting - but the fan continues to run. Had to turn the fan/ AC off to watch TV or talk while eating.
The two metal posts and heavy table top for the dinette is a real pain.
The toilet/shower are very small.
At the time we bought ours, the trim level was low. The edges of the plywood platform for the bed were rough and tore the bottom of the mattress cover on the second night.
Of course the mattress is a foam brick. Buy a mattress topper. Your back will appreciate that.
I've looked at a lot of reviews. Most of the issues people describe boil down to expecting Arctic Fox or DRV Suites quality out of an entry level trailer at the under $20,000 price point.
It is a good trailer / line for people wanting to get into the RV experience. It is not a good trailer for someone wanting to spend 100 days a year in the rig, travel coast to coast or camp in near freezing weather.
Enjoy the rig, but know its limitations.
EDIT - one of the 10 or 12 people I know with a Grey Wolf trailer is an elderly widow with the 26 BH. She took out the sofa and built a sewing machine table over the furnace and out about 3/4 the length of the sofa with a small household freezer on the other end. She took out the dinette, added a shallow floor to ceiling cabinet along the back wall with a better, larger TV, and a recliner in the remaining space.
I have the same trailer. Just wanted to let you know that there is a access panel to the water heater under the mattress right above the water heater. - LUTExplorerLast September we bought a new Grey Wolf 26BH and are very happy with it. We were at Ft Wilderness in December and everything worked well.
The trailer tows well with WD / sway control and Prodigy brake controller.
I've had no issues to date and think the finish and fittings are excellent for the price we paid. I especially like the power awning and jack. The electric/gas water heater worked very well. The only mod I did was to run a TV coaxial cable to the bedroom area from the connection over the dinette.
The dealer, Tri Am in Ocala were good to deal with also.:)
Amazing really, especially reading about some of the problems posters have with their "higher end" units. - colliehaulerExplorer IIII own 2 Cherokees not the lighter Grey Wolf. I have a 30FKS that I use as a seasonal and a 22' TH. I have been very surprised how well they have held up for being entry level trailers. The 22' TH is a 2004 with around 35K miles on it and I have had zero problems. The 30' FKS is a 2005 that I bought used that I remodeled the interior for my seasonal site. Both have 81" interior height that makes them very open. I plan on keeping them another 7 years until I retire then I will upgrade.
- PawPaw_n_GramExplorerWe purchased a Forest River Cherokee Grey Wolf 26BH in September 2011.
EDIT - one of the 10 or 12 people I know with a Grey Wolf trailer is an elderly widow with the 26 BH. She took out the sofa and built a sewing machine table over the furnace and out about 3/4 the length of the sofa with a small household freezer on the other end. She took out the dinette, added a shallow floor to ceiling cabinet along the back wall with a better, larger TV, and a recliner in the remaining space. - sbowman871ExplorerPart 2, A better look.
http://youtu.be/5sQjY1ALy4A - Huckster1037Explorer
Goldstalker wrote:
http://www.youtube.com/watch?v=yixB3piNtmk
So all I saw was a totally black video with someone describing something that we can't see. What am I supposed to be looking at? I have a Grey wolf 28BH - Dick_BExplorerYou could check with the RV Consumer Group for a more objective appraisal; www.rv.org
You could also search this Forum for `Grey Wolf' to read previous posts. - TECMikeExplorerWe have a friend and his wife bought a 2012 Greywolf. Believe it is about 26 ft long.
They have had absolutely no problems with it and have used it a lot with their children.
Sure, it is a basic entry level, no frill model with bunks, but it works just fine for them, as their budget would not allow a more expensive trailer. And it lets their family get into the marvelous world of camping.
