riven1950 wrote:
I am looking at a 2013 f150 ecoboost. For those that may already have one I have a couple of questions.
1- Some trucks have a 3.31 electronic locking rear axle, others have a 3.31 regular axle. Other than cost ( 420.00 ) what is the difference and would it matter towing? The one I am most interested in actually has the electronic locking rear axle.
2-What kind of mileage do you get when not towing ( city / highway / combo )?
I know towing mileage will likely not be good even though I would only be towing about 4000lbs, it is still a box holding me back.
Was real impressed with the power vs the v8.
thanks in advance
I don't tow nearly as much as I used to (personal reasons) but I have approximately 7,000 towing miles on the Ecoboost Truck with my trailer. That's over an almost three year period and previously I would tow twice that much each year.
Since your truck already has a 4X4 option it's not likely you'd have occasion to use the locker when towing. One POSSIBLE exception would be if you get WAY off the beaten path and camp deep in the forest using fire roads etc (I often do that with only a LS rear end).
Towing mileage is not that much better than I got previously with the 5.4 V8. I got about 8.5 to9 9.5 with the V8 and I get right about 10 MPG under most conditions with the Ecoboost (my trailer and travel load is over 10,000 lb). BIG difference is the over all power and the performance at high altitude (no drop off at all). That's an advantage only diesels can match. For what it's worth I almost NEVER go towing in a city so city towing MPG is a "non issue" I HAVE found that the "Miles to empty" feature is accurate enough even with mixed towing/non towing miles that is is actually useful.
Non towing MPG is 'good" but you CAN do better on a couple of different trucks but you sacrifice all that power to do so. If you're buying for towing purposes you will LOVE the ecoboost. I regularly tow up to 8% grades in 4th gear at rated speed limit (that's high gear as fifth and sixth are both OD gears). ON the down side the engine braking is not QUITE as strong as with a big V8 engine but it has never caused a problem, as you simply adjust your driving style to compensate for it. At the bottom of a long downgrade you can easily still lay your hand on my brake discs.
Good luck with your decision / Skip
BTW: 35,000 miles on my truck now and it's had ONE repair (they left a screw loose on one of the intercoolers from the factory which set a "check engine" light. Happened on the way home from picking up the truck and I purchased mine so early that there were no manuals sent to dealers yet so had to wait a day for a factory rep to arrive to trouble shoot this very simple problem. He tightened that screw and it's been smooth sailing ever since :)
