BubbaChris
Jul 07, 2015Explorer
The first reply on this thread and the chart Dakota98 posted are really, really good.
As has been noted, you can get the AC running in most situations with a 3100. But the trade off is in weight and you don't need all of the capacity when you aren't needing AC. So most often people will go with a paired set of 2000 units. That way you can run (or even only take) just 1 if all you need are your batteries charged and the ability to run the microwave, etc.
I spent last weekend dry camping at a CG where we believe a full half of the RVs there were using generators. First time we've seen that many as a percentage. Number one in quantity were the Hondas, and pleasantly surprised to see some going as small as a 700. We walked by Class A and Class C motorhomes with onboard units that sounded louder than the Hondas. And we saw one guy with a toyhauler who had consistent problems getting his onboard started (at 8,600 ft elevation).
And then there was the 1 open-frame generator. It's not just that it was louder, the mechanical noise (not just the exhaust) is part of what makes it cringe-worthy. Luckily they only ran it a little.
I mentioned the altitude earlier and that's part of why I have a single Honda EU2000i. I have the high-altitude jet for the carburetor and can change it out in under 30 minutes (at home). All my camping for the next couple of months will be at 7,000-10,000 ft, so I already made the swap. And if I need the AC, I can buy a second EU2000i and pair them.
