Huntindog
Jan 29, 2020Explorer
BarryG20 wrote:??????
I also would look at the gy endurance
You might think about the 215 size instead of the 205 size as it gives you a bit more weight capacity and isn’t any larger diameter so should fit fine. Though not knowing the weight of your trailer you may not need any additional weight capacity cushion
All other specs being the same, a 215 WILL be taller than a 205.
Not saying it won't fit, or that it's a bad idea.... Just that it WILL be taller
44,061 PostsLatest Activity: Apr 09, 2026
