Mike134
Jan 29, 2020Explorer
Grit dog wrote:
Rotating trailer tires is like rotating the air in your tires.
Unless of course the trailer is messed up or hooked up improperly causing more wear on certain tires in which case rotating good tires Into the bad spot is a bandaid for the problem.
I disagree. With a double axle trailer one of the two axles will tend to skid the tires around sharper turns more than the other axle wearing that set out more. This will be very evident when backing into your driveway. Just the nature of the beast with fixed axles.
44,071 PostsLatest Activity: Aug 30, 2026
