Brandon_the_Tra
Oct 18, 2021Explorer
You need to look at the bunk doors themselves, and the wall areas below them. Go over then with a fine tooth comb. Those R-Visions were well known to have leak issues that resulted in rot to the doors and areas below the doors. The screw down bunk locks were one of the first designs used to secure the bunk doors when closed, and did not work well. If the doors are shot, you will almost be SOL as replacements will need to be custom made. People have done it but it's not cheap.
